- 29 Aug 2010
- Cornwall
I'm a little curious about the 900D with regards to the bit that says it can take 2 480mm rads in the bottom. If you do that, where does the PSU go?
I have just seen the 900D listed over on Corsairs website.
I have just looked on the website and the case cost $0.00
Perhaps a typo in the tech specs then!
Yep PL will be getting under way as soon as the case lands and I can start rad planning. At the mo its looking like 1080+360+360+280![]()
