Folks.. can I ask.. what is the advantage of these multiplayer sessions of Fsx? I mean if you dont know the people and when you fly around how do you know where they are etc? I guess the real question what does it bring to the game?
I'm trying to learn to use the FMC. Total mind boggle. I'll get there though.
Got the shared cockpit business up and running but I did have to open UDP Ports 6112 to 6122 through the router on for the host PC. Don't recall seeing that mentioned on the Virgin Forum linked to above.
For those interested in VATSIM, in a shared cockpit, you can see/hear all that needs to be done for flying online with the added benefit of someone with more experience.
The Cessna 172 is a great plane to start with.
. Yes at first it can be quite overwhelming but you soon get over that. I'll be online with you guys soon it's just doing my head in trying to modify fsx for my system. Problem I'm currently having is sids not showing in PMDG FMC. I'll try a reinstall if that doesn't work then I'll have to ask on the pmdg forums.
If stationary it stayed put, if it was airborne the 3rd player saw the plane continue with the tradejectory the plance had when control was passed over. However the speed was sent so if the student landed the plane fell out of the sky. If control was passed back to the sharer then the 3rd person would suddenly see the plane appear in the correct position. Very frustrating.
Anybody had this issue or know a fix please?Couple of questions please.
I'm having some issues with my joystick. Ever plane I fly it just wants to pull me to the left the whole time, a bad pull I have to really fight with it (never had this before). I've re-calibrated the joystick and still I have this issue.Anybody had this issue or know a fix please?
How do you avoid seeing snow on the ground? I know its winter and I know we getting some snow but the whole of the UK cant be snowed in?
What Joystick? My old logitech extreme 3d pro used to do that. Contacted logitech and they said it was a driver issue (which it isnt) so i complained and they gave me either a 50% or 75% off so i bought a new one, works fine now.
Yes that's the one. I's strange, it has never done it before. Which one do you recommend please?
That FTX Global looks mental, will defo drop £ on that one. Stupid FSX default textures cant wait to be rid of them.
I hope someone makes a new sim, FSX is creaking. But still chuggin along thanks to Orbx and all the other great addon sceneries and planes!!
Jason I recommend using Navigraph for your FMC data. It's not too expensive. It will update your FMC with the latest sids and stars.
Very easy to do.
http://www.navigraph.com/www/fmsdata.asp
I've started getting this as well. Haven't a clue what's causing it. Pelting down the runway and the plane just starts turning left. Annoying to say the least.
V, has a recent Windows update cocked-up the driver? Good service if that's the case with a replacement from Logitech!
Is "auto-rudder" disabled or enabled? I'd guess it is enabled. Try disabled and see if it makes any difference.
I haven't been flying in a while as Windows 8 is randomly freezing for no apparent reason and nothing logged in event log either. Very odd (and annoying).
I went for a quick flight last night on VATSIM. Manchester to Aldergrove to check out my new 2 x PC setup.
Manchester Ground, Tower and London North were online for ATC coverage.
It worked reasonably enough after 2 crashes of FSX. Surprisingly, the FSX PC was showing a really high CPU usage in task manager so goodness knows how it was coping running everything else.
It still requires some tweaking, but it could prove a useful until a new PC comes along.
So who's using Opus weather?
When are we next flying online?!![]()
