You take fish oils? Just wondering about your elbow pain.
I have Good Oil every day on two meals which has Omega 3 in it. Not cod liver or anything though
Just hitting strength for a bit in general. The 5x5 on the squats is to help with getting out of the hole (I believe) as I'm terribly weak there.
I'd love to say aren't you weak everywhere, but you're stronger than me
kd
Squat vid from today, trying to be explosive out of the hole, did the 1x5x100kg set prior.
Yeah form is definitely going on your deads, only one or two reps with a straight back in there. And one for ice or similar to answer, but I really don't like the complete lack of negative. The weight is pulling your upper back completely bent over as it slams down and your arms turn to jelly - this surely can not be good for your back, shoulders or elbows?
Also, get straps for BORs.
Would like some further info on it really so I'm all ears.
<3
Get straps then reassess. You might find more back activation at the same weight when using straps.
upper back bend when pulling isn't that bad, can't imagine it being good when it's the weight yanking it back on the 'negative'.
No your arms turn to jelly because you're not in control of the weight, it's just crashing back down. However because your still gripping the bar, I'm thinking it's going to be pulling your shoulder around in the socket and I worry for the elbow too. I don't know enough about joints to know if these are valid concerns though - hence why I'm posting for ice's attention. It just doesn't look healthy to me.
Also when you say "not doing a slow negative", there's three stages in my opinion:
Slow negative, normal negative, no negative
My problem with your lack of negative, is that your back is not moving back down to the starting position as fast as the weight is, you're being dragged.
Edit: I'm not having a go or anything, just don't want your fragile shoulders getting ripped out the socket![]()
So thank you
might want an edit on your first line lol
as for the deadlift negative i think i pretty much do the same, and i feel no tension etc in my back, and no adverse pulling on my shoulders, but Monkee may have a point.
Re straps, get some for things like RDL's and BOR's i am going to and i agree that for a few select exercises, grip should not be the limiting factor and you might not realise it is until you strap away.
Your welcome to try mine out when i get some if you want.
Mine are some cheapies from bodybuildingwarehouse.com or sommat, was given them by a friend.
Syla5, you might return to position a bit quicker, I'd have to watch your video again.
Delvo, it might just be the case of the dreaded back pump. Doing negatives slow will give you a much bigger pump. Taurine can help and is dead cheap.
Whey, dextrose, casein, now instant oats...Possibly taurine!I know you're having a go mate, I appreciate the feedback, it's why I post the videosSo thank you
