Is there a nack for getting films transferred to another S3 via nfc/sbeam or should it work all the time?
There's 4 people at work who Ive tried to send films to with the above method and most of the time it fails. It can be 10% into the transfer or 100% (was just about to finalise and then failed). Ive tried a gap of a few mm's to a few inches and its always the same.
Makes me very![]()
I've had success just doing a few photos between mine and my brothers S3. Haven't tried anything larger than a few mb though!
Also is there a certain kernel people have found to be best having used the aosp jellybean ROM on my s1 will probably go with his s3 version unless any of you know of better ones. I have always used Odin to do the kernel is that still the way or is there something new. Look forward to hearing from you experienced people I tend to find a kernel and ROM I am happy with and stick with it not as adventurous as some of you.
Best kernels are either Siyah Kernal, Perseus or Yank555. I've used all three. Siyah and Perseus are configured through an S-Tweaks app. Siyah has a lot more configuration options than Perseus, but they're fairly similar. Yank555 is flashed through cwm and configured in an Aroma installer.
Siyah and Perseus can be flashed through odin as a .tar or through cwm as a .zip
