How about something like Viewranger?
You can download 1:25000 OS maps and it will follow your route using GPS, so you don't need to be in range of a 3G transmitter at all, if that is the sort of thing you are after.
It might at least be worth a look anyway.
You could.. you know.. root and flash CM10.1
You'll never have to fart around with custom sms apps and themes again![]()
 Although I am getting very bored and tempted to root etc. now
go sms tends to use an approximate time for messages unless you enable 'strict' timestamps I think... try that (unless it was a good ten/twenty minutes out lol then it won't help that)
 Will reinstall again just to make sure though.What's the best alarm app guys? Friend of mine recommended Gentle Alarm bit it doesn't look very pretty from the screen shots. Just want to be able to fade in mp3s,and maybe easily swap between loud and quiet alarms (I sometimes wear earplugs)
As said before, too much faff requiredAlthough I am getting very bored and tempted to root etc. now
He needs to find a rom, download it, download the tools he needs to flash, carefully study the instructions to make sure he does not brick his phone, carefully go through the steps of unlocking - rooting - flashing, donwload all his apps again, confirgure all his apps again, realises he has to play though half of the games he's started playing from the start again, install some root apps, tweak the rom settings, set up his homescreen again and because he now can backup all his apps with a program.
Oh and I didn't mention, that horrible wait where you don't know whether it's in a boot loop or not, gets me every time.
I think I'm finally going to root my ONEX so I can use datasync on my tablet and phone![]()
How? If you are experienced it would probably take 10-15 mins to root and flash a ROM. If you are new to it and following a guide etc maybe 1 hour?
How long do you spend fiddling around with configuring apps and themes etc? Probably about the same amount of time I'd expect![]()
You say that, but that has not been the case on phones or tablets I have rooted. Unlock/root requiring a wipe.root first (if possible - it should be)
I was speaking RE customization though, I'm going for the functionalityAll those cons you've listed, and you're going to root anyway
He could always root his current rom and do a titanium backup. No data loss
edit: kona beat me to it.
I'm thinking it's more the having to update them etc everytime a new version comes out... That's pretty much the only thing putting me off doing it, although I'm getting more and more tempted if there is some really worth having benefits.
5 Minute download once every week or so, flash over the top of current rom.
Hardly a hassle![]()
Oh WOW! I thought it'd be the entire install process over and over
So does that mean it'll leave all settings as per before the update?
I've been looking at CM10 but read on a few places that camera/bluetooth might be a bit iffy on it on the One S?
