Barbell Bench: You didn't fail a set but moved the weight down? Why?
Dips: Why not just try +5kg for working sets? Stop pyramiding sets as you can't find what your working set is comfortably.
There just doesn't seem to be much method behind your weights. They just randomly go up and down. You need to actually push yourself.
Regarding previous deadlift form:
IMO you're still not getting tight and your hips are moving before the weight does every single rep.
Regarding squats:
Failed on 2nd set and 3rd set lacked depth. Which implies your lighter set probably isn't light enough to work on speed, especially when fatigued.
I generally have had problems with my shoulders doing this and I don't want to put excess strain on it, there just isn't any point in it currently.Hole, it's hole![]()
Well yes, they're different because they're different exercises
Stepping back on OHP implies you're losing the bar behind you, so you need to keep your glutes and core tight tight tight. Otherwise you'll hyperextend and bye bye backywacky.
A lot less pre-push involved.Get a vid up if you canYou should be pushing the bar straight up and them shift body underneath it when the bar is past your head, like in Monkee's vid.
Increase the weight if you want to get stronger - just lower the reps.
There's not much scope to lower the reps when he's already working on 5x5
Delvis' shoulders are very far behind the rest of his development due to injury and neglect, I dare say it's gonna take a lot of pushing to make them catch up.
Was you doing the dance too?![]()
