Anyone know of an app that can wake the device up using the volume buttons?
WidgetLocker no longer does this since i updated to latest PA rom :/
Android settings > lock screen > volume rocker wake.
Ahh thank you. I forgot i had to enable it in there rather than WidgetLocker
 I've been using light flow for a while :E
 I've been using light flow for a while :Ehaha no worries, I've only just figured out it has its own LED notification controls too!I've been using light flow for a while :E
Where are they??
Im using LED Blinker at the moment.
I'd love to know how to make the menu bar a little transparent too. I know its possible within PA but have no idea how to do it..
Display > Pulse Notifcation Light & then you can set up custom ones there.
To get transparency on the menu bar go to Hybrid properties > apps > find your launcher > scroll over to colour & set the transparency there. Under either status bar or navigation.
That works. However, it does not apply it system wide :/
Launchig apps like Gmail, SMS and all the others changes it back to default colours/values
 If you're on 4.1+ you can disable notifcations (this will include text ones though) in the app profile under app management.
 If you're on 4.1+ you can disable notifcations (this will include text ones though) in the app profile under app management.Best way to install Cerberus on a rooted phone?
The way I've done it currently - I've downloaded the apk from their website and installed via cwm?
Flash the .zip in revovery.
How does one go about sideloading apk and converting?
Not sure if you can do it with every app but just check each & every app in the same area as the launcher one.
You can install it like a normal apk using a file explorer, then use something like Titanium Backup to convert it to a system app.
Or you can place the apk in the /system/app partition and reboot your phone.
Or you could just flash the zip in recovery, as it's much easier
