I did but i came across this alos: http://dottech.org/21534/how-to-ins...ows-computer-for-use-with-your-android-phone/
Ah i see, What does the toolkit do now you've done that?
Exactly the same thing :/
Are these the characteristics of a "bricked" phone?
Nexus Root Toolkit -> Advanced Utilities -> Fastboot- Bootloader -> Flash Zips -> File is on this computer...
You can also flash a bootloader, custom recovery, push files to the device, and a myriad of other things using the toolkit.
This has put the files on my phone. Installed PA
All is good!!!
You my friend are awesome!!!!!
Thanks to everyone who has patiently helped me for the last 3 hours. Much appreciated. Android community sure is a lot better than apple's!
Thank you everyone!!!!
Nice one guys glad the outcome was successful!
Now I wouldn't recommend formatting everything again lol.
Jamie23 said:One problem I've just encountered is with my virgin sim.
Just cut it down to size, fits in the tray no problem however on powering up it says "No Sim Card" and when searching for available networks it doesn't have virgin displayed . Yet if I try and register with any of the others it will give me "Your sim card does not allow you to connect to this network" or something to that effect.
Apologies if this is an easy problem or I've forgotten something, first new phone in a couple of years.
I have recently got a new Nexus 4 (my first proper smart phone). I'm having a bit of trouble with my mobile internet, i'm with giff gaff.
I usually get a 'G' signal indicator which is quite slow. However I sometimes I get 'E' (a bit faster) and 'H' (much better).
Should I be getting a signal '3G'?
Just cut it down to size, fits in the tray no problem however on powering up it says "No Sim Card" and when searching for available networks it doesn't have virgin displayed. Yet if I try and register with any of the others it will give me "Your sim card does not allow you to connect to this network" or something to that effect.
