Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Fixed the time but TV catchup still don't work...confused.
Whoops, i just use the XBMC Commander app on my phone. I think its the equivalent of the back button.
Maybe its just the way the skin is designed then. I'm sure the normal skin effectively stops the video when you come out of it.
Just bought myself a Logitech Dinovo Mini. Interested to see how that works![]()
Wanting to build a xbmc computer. will run windows 7 x64.
amd fx57 cpu.
4gb memory
ati 6450 1gb graphic card.
msi motherboard diamond.
64gb ssd.
1tb western digital hard drive.
will this run on a 55 inch lg smart tv.
wanting full 1080 and use 3d as well.
is this a capable system,before i build it.
just using parts i dont need anymore.
thx in reponse![]()
It would but tbh running a windows 7 64 on a single core cpu in this day and age is not really worth it
Build it then see what have you got to lose if you already have the parts.
I've used hostname, but I'm only running Windows so far, which likes DNS names - Android doesn't seem to like local DNS names - so that will be a consideration - if you're looking for adding Android devices, you might want to use IP addresses.
Question on stand up.
How to people sort this? I dont really want it in my movie folder, and theTVDB wont scrape them, wondering how I should go about this.
Ive set my server up after months of messing about, copying over 2tb of data is taking soem time!
