- 22 Jan 2006
- Lincoln
So are you gonna tell us what it was?!
My misfire came and went by itself. But I still sometimes get a flashing EML on idle when it's cold
Tempted to replace the coil pack to see if that helps. It's deffo not an injector as the only fault code is for the O2 sensor - which isn't broken as I replaced it already.
Coilpack
Changed the HT leads first, no dice. We had it on the tuner box to read fault codes but there weren't any, which was odd. So took the two simplest, and most common ones to check. (knew the plugs were okay as I'd checked them the day before).I've now done a preliminary deal for some eibach Prolines. Look in relatively good nick, and at £80 and local I think they're cheap!
