3 photos! Bare in mind that these aren't the best conditions now to show this off and supposedly the units aren't the final version so the camera should be better with the proper retail units:
http://st.gsmarena.com/pics//13/02/htc-one-samples/camera/gsmarena_003.jpg
http://st.gsmarena.com/pics//13/02/htc-one-samples/camera/gsmarena_001.jpg
http://st.gsmarena.com/pics//13/02/htc-one-samples/camera/gsmarena_002.jpg
Looks pretty good there
http://blog.gsmarena.com/here-are-the-first-samples-from-the-htc-one-ultrapixel-camera/
EDIT:
EDIT:
Hmmm, just remembered, what about the menu button? With the one S/X you have a tweak so when you hold down on the multi tasking button you get the app menu, but if you don't have that option enabled it means you have the evil 3 dot menu button on the bottom!!!! (developers need to remove it)
Deal breaker right there for me
EDIT:
wow! Excellent image cymatty to show exactly why Samsung brain washing marketing is so good now!
in theory, while you will be sacrificing some detail in well-lit environments, you should be getting better low-light results. Add the super bright F/2.0 lens and you should be getting the smartphone with the best low-light performance in business. And since you would be downsizing many of your images anyway, this seems like a fair trade to us. As long as the HTC One delivers on those promises, that is.
As it turns out the shots are pretty good, considering the less than perfect environment and their per-pixel detail is much better than any of the smartphones we have recently reviewed. It’s not quite able to come close to the performance of the Nokia 808 PureView, but that one has a sensor 6 times as big as the HTC flagship.
EDIT:
EDIT:
EDIT:
