Caporegime
- 9 Nov 2009
- Planet Earth
Yes, that's the case normally. But this isn't a normal run. The titan is made up from binned Gk110 parts that didn't make the Tesla cut. We know from Gibbo and 8 Don that the yields are terrible. And they don't make huge volumes of Tesla parts, not near as many as consumer cards, so there won't be that many to begin with.
Knowing all that, Do you really think that there will be enough cast offs from the Titan run to make another series of cards? Not a hope.
The Geforce Titan uses the full GK110 found in the K20X,but probably those which would not quite make the cut. The K20X is a much more limited availability part than the K20.
Most of the GK110 based Tesla cards will be the K20.
The K20 is more easily available than the K20X and uses a partial GK110. There are likely to be far more GK110 GPUs available for the K20,so what happens to the ones which did not quite hit K20 standard??
At the very least,I can see if not a GK110 based GTX780(GK110 salvage part),I can see them being sold in another consumer card,unless they become Quadro parts instead.
