Also, if i post a pic in the fb group, its locked down right? no one can see apart from the rats?
Pretty much.
You're not doing a nude, are you? It's not that kind of group...
Pretty much.
You're not doing a nude, are you? It's not that kind of group...![]()
What's better... Chin ups or pull ups?
I'm assuming chins work your biceps quite a bit more but which is better for back in general?
http://www.amazon.co.uk/Gymnastic-f...sr_1_1?s=sports&ie=UTF8&qid=1361475270&sr=1-1
Any issues with these? Cheapest ones that are adjustable from what I can see. Only issue is the 'cross fit' in the title xD
Anyone know of/recommend any different ones at a similar price?
kd
Mixing them is good. However pull ups are great for width. And perhaps start with pull ups and finish on chins. Add some weight to be hardcore!![]()
Those are the ones I have. So what if it has cross fit in the title?
Love this. I'm still struggling with BW DAMN YOU!!!
Pretty much.
How hard is tieing a knot?
Straps are about 2m long, so hang down a meter when tied. I've left mine tied now so i just hook them over the pullup bars.
To be honest any one able to do bodyweight exercise is considered strong in my book.keep at it.
It isn't?![]()
