- 22 Jul 2012
- London
Sod that then. That's half the fun gone...
Oh well, it's partly my own fault anyway. I had meant to get this done yesterday, but got caught up in other stuff.
If you're not fast, you're last as they say.
I had a look through the last 4 pages, didn't find it and ended up doing a thread search. Nothing came up for 'HIS' or 'VRM' strangely
Not bothered really as I don't want an HIS card
Nae matter, we'll see what OcUK say. I've been without a card for a few months now. I can wait a little longer.
Yes it was the His, you get the powerjack thinamyjig with it too iirc.
I didn't think the ref 7970's would have changed from original spec being ref, but would be better of checking to be sure than sorry.![]()
He's got an IceQ 7950 at the moment.
The his uses a non reference board with a reference cooler. I used one in a build not so long ago. It was a horrid blue board and it was considerably lighter than my launch reference 7970. I would avoid it if clocking tbh.
EK really need to sort out their Cooling configurator. It shows the HIS as a reference board.
It's probably not their fault as manufacturers keep changing specs and instead of using new product codes, they just add 'rev' on the end. Must be hard to keep up.
Still showing as in "Printed in Warehouse".
You can have mine, that's for sure. I'm not really the patient type so the tape sounds like the better option for me. I'll be buying mine friday, as soon as I get it I'll pm you and get it sent over.
Is there much difference in temps with the tape once it's bedded in?
Hopefully they will find a couple stashed somwhere....
