**** Official Titan owners thread. ****
Greg... I would suggest going coloured tube and distilled water with a silver coil when you redo loop to include the titans... Nothing to clog anything up or stain anything.
Nice looking rig gregster especially with two of those beasts in there!
But you really should dust that rig down man:D
Slightly off topic but the current coolant your using.. it wouldn't happen to be Mayhems Aurora Tharsis red would it?
The reason i ask is because i'm using it, but it's only been a week and it's already lost of of it's sparkle, so like you i'm thinking about getting coloured tubing next week.
Ok,ok I will give it a good de-dust :p
Just done 2 bench tests in games and Crysis 3!!! Ohhhh Mannnnn, killer :(
Frames, Time (ms), Min, Max, Avg
7729, 300000, 16, 35, 25.763
First mission (in the rain on the ships) and everything maxed with 8*MSAA
Will an 850w psu handle
x2 Asus GeForce GTX Titan 6144MB GDDR5 PCI-Express Graphics Card
Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail
Gigabyte X79-UP4 Intel X79 (Socket 2011) DDR3 Motherboard
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Red/White
Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW)
GeIL Enhance Corsa 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (GEC316GB1600C9QC)
Yes :)
That Aurora is more for showcasing and not permanent bud. It can clog quite badly in a short period of time. I am using Pastel Mayhems, which has 12-18 months before needing to be changed.
Greg anychance you could recommend a 850w psu for 100£ or less bro
Don't skimp on a PSU especially one where your potentially drawing this sort of load. Cheap units have a tendancy to take your equipment out or worse burn your house to the ground. If you stick to Seasonic / Corsair you won't go far wrong.
Work out your max load first and go from there.
Yes :)
Thanks for advice pal,
Looks like i'll be swapping this stuff out for some pastel stuff then next week.....now.....what colours.....hmmmmm.
7729, 300000, 16, 35, 25.763.
I read one review of gpu performance tests with Crysis 3, they named it the system killer, and this was only on High settings with 4xmsaa medium :eek:.
Titan SLI @1920x1080 had very nice framerates (95fps) but @5,760x1080 was just under 40fps.
