I don't know why it's so difficult for people to implement a semi-reasonable set of filters and a nice UI
It's not. I posted you the answer already surely?
Does anyone know how to change the color of the notification square that appears when you get a new text or email ect Tesla Unread plugin I'm taking about.......
As far as I know, chrome has always displayed these forums badly. I've always found it quite poor, from day one it used to make my (then) S2 freeze horribly.
It was okay before, its just the new text rendering that looks worse. I'm on the default Android browser on my Tab now and it's so much clearer. Performance is much better too, so it looks like I'll be using this until Chrome can match it.
Random question guys- I'm new to Android, there's a little icon in the status bar next to the signal meter, the icon looks like a little speedometer- what is this?
Nova settings > Look and feel > colour theme.
What's the deal with Google drive/docs ? I can edit excel docs but not word ? Or am I doing something wrong ?
What phone? If you could take a screenshot (google how to, it's not tough) it would be easier.
Sounds like a battery percentage mod. You on a custom rom ?
Just installed a new font and then had to reboot. Now im stuck on the PA boot animate.
Is there a quick fix for this or do i need to wipe and do it all again?
Try flashing your ROM over the top, wipe cache, wipe dalvik.
Might work, might not, won't wipe anything, no harm in trying
I just wiped everything and started again.
The whole process is pretty fast so didnt take long. The annoying part is setting up all the preferences again for all the apps. Wish Google would allow app settings backups :/
Think im going to create a nandroid back up just incase i screw up again in the future but the only problem with that is that nandroid backups do not save the SD card portion of the Nexus 4......
Have tried to google but doesn't come with anything except speedometer apps.
And no not on a custom ROM.
 You sure ur not on custom rom? That battery icon isnt a stock one. What phone is it?
