- 9 May 2006
- Nottingham
Just flew a chopper with some guys in the ocuk server. This game runs beautifully at 2560x1440 with most settings on very high
is there a TS/Mumble server for the OCUK wasteland server?
Just flew a chopper with some guys in the ocuk server. This game runs beautifully at 2560x1440 with most settings on very high![]()
Your kidding right?
What settings are you running to enable that?
No post processing, no v sync. 2 x fxaa. Turned down visibility a little. I'll check them later and tell you 100%. I'm very surprised at how well the game runs!
I also set the CPU count to 8 so maybe that helps a bit.
Maybe the i5 is hurting me in comparison.
. I play a lot of wasteland on arma 2 in the ocuk server and now that I have arma 3 ill be on the ocuk server a lot too
. I'll see you on it again sometime
True, but they could add noise to the distant textures to boost visual quality, and just redesign the tree's and sorted, the game would be superb.
All AMD CPU's are NOT Hyperthreaded so Hyperthreaded options is highly not recommended as this can cause system failure or damage.
I will not be responible for system failure and damage if you choose to select more cores then you have on your command line!
