Man of Honour
- 5 Jun 2003
- Falling...
I think I prefer your new form too. Looks more controlled - better back position. Bar comes up more smoothly too.
Did you try to brace your core as you went back? Trying to reclaim position once it's broken isn't the same thing.
It's likely that there is something tight in your hips.
Dat short femurs
Bro, get on some high bar squats and ensure you have proper ankle range for joocy Chinese weightlifter quads.
Dat short femurs
Bro, get on some front squats and ensure you have proper ankle range for joocy Chinese weightlifter quads.
Tbh I'd be able to judge better with a squat.Looks okay for the most part then?
I've short legs & arms and a long body!
Some errector strengthening/endurance work along with some general hip, glute & hamstring mobility & stretching and some planks/pallof press is on the agenda.
I'll take a look in to high bar squats and my ankle mobility.
Thanks.
Also this!Just thought I'd fix that for you.![]()
