Pink LEDs are cool!![]()
Browns are a very good all-round switch!
You will like them when gaming, and for when you aren't gaming, you will really like them. a lot.
Ok after looking around, I think it's between:
1) Cooler Master Quickfire Rapid
2) Ducky DK-9087
3) Filco Majestouch-2
All are available as TKL which is perfect. Assuming all were available with brown or red switches, which one should I go for? The CM is cheaper but it's almost impossible to find in the UK with brown and red.
I've noticed another thing amongst the Filco range. What is the difference between tactile and click keyboards? The only thing I can find so far is that the first use brown switches and the latter blue. Is that simply it?
Ordered my Ducky DK9087 TKL with Red switches and Blue LEDsI would have loved the Filco Majestouch 2 but I could only find it in stock with the Blue switches.
If we are talking about the same dealer, I couldn't see any Red switch TKL ones. Another thing that decided it for me with the Ducky was that their function keys also had the track labels printed, which I use often to control my music playing in the background.
I looked too with no luck. Seems like it's locked down, and only some laptop BIOS' have the option to disable it. Let me know if you find any different.![]()
Just arrived at work. Oh man, I just love the keyclick sound! Can't wait to take it home and see how it performs for games. Already looking at ordering some custom keycaps lol.
Trying to figure out how I can make it so that the media keys work instead of the function keys by default without having to hold the fn key every time. I don't use the function key much to be honest.
