- 29 Feb 2012
- London
Have you order some blocks yet kaap ? All of our Titan builds should come together around the same time
Yer I'll have a think as for the moment I'll be using the 27Dell which is a fantastic monitorHave you order some blocks yet kaap ? All of our Titan builds should come together around the same time![]()
Didn't mean to quote dam iPhone
Aye, got 4, not installed them yet, but indications are they will get between 80-100K each.
Kaap the nice thing about the Aquacomputing blocks is that they are so thin. It gives you real flexibility in placement. This is my old 470 rig:
Could you mount fans at either end blowing in the gap between the radiators?
or even have them both blowing in with fans at front and back of case pulling air out?
no point to 92mm as a case fan really,
I'd personally try it as a wind tunnel for a bit. better get testing![]()
