- 12 Feb 2009
- UK
Has anyone bought a load of the med blades and be willing to sell a few? Buying 10 online to try works out at over £6 when you add delivery. Looking for maybe 3 or 4 to try out.
All three red tips versions? Lucky ****!You'll need a rack or display case soon
You might be better off starting a 'spec me a beard trimmer' thread as this is all about manly shaving with chunky metal instruments and cold, sharp steelDoes anyone have any recommendations for a good trimmer or anything with an adjustable height for a good even length shave? I want to maintain a nice even look to my facial hair but theres so many options I dont know where to start, and i'd rather not just buy one and test it out or I could be there all year until I find a good one![]()
I keep eyeing up Rodney Neeps brushes, since mine annoys me. Was planning (if I went ahead with one) with a custom extra silvertip of some sort. Will I really see that much of a difference over my best badger Edwin Jaeger thing I got with a set?
Also concerns me when I read his care instructions on brushes, mine loses a good 6-10 strands of hair each shave, it just seems to constantly be falling out, so either im doing something wrong in caring for the brush, or its poorly put together.
All these guys getting rashes and irritations, it's bound to happen. What I've found with shaving is simple:
- Your skin must be awake
[*]It's no good having a hot shower 1st thing in the morning and then trying to shave in 5 mins. Rather, shave later in the day (before bed) or later in the morning if possible.- Don't just splash your face with warm water. It needs proper softening up and the only way that's going to happen is with steam, lots of it.
- Even better, shave in the shower (get a tile stick mirror)
- Go with the grain almost all of the time apart from tidying up
- There is no science in lathering with or against the grain. Get the brush and mix it up properly on your face. You want to raise the hairs here (agitate), not lie them down.
- Stop being a fool and using bar soap and moisturiser. Get proper shaving foam (not gel) and a decent brush.
I bought a Merkur thingy in 2009 and the pack came with a badger brush and a selection of 30 blades. I have about 4 blades left, of that original pack. That's some serious money saving!!![]()
It's the whole hair, I've also checked for the tell tale white ring and can't see anything (doesn't help that the hairs are pretty light anyway), always rinse till there is either no or very little soap smell on the brush and dry by brushing on a towel, then leave to hang on a stand, not that it's helped any.
Will give the vinegar a go, but think your right that it's probably just a pretty poor brush. I've heard of the Simpson Duke's, are they really as good as the custom Neeps?
