On holiday, but decided your video merited some abuse...
"Devlis, you wet lettuce, there were at least another two at 110kg!"![]()
Great work! Keep it up!![]()
Looking good, I actually think you move better on the 150kg than the 140kg. How did you find them?
Actually looks to me (and I guess would relate to half your shoulder issues) that you're not actually pulling your shoulders back and pushing your chest thru when you set up, something I think you need to work on. Otherwise you're not going to be building those big strong traps to help keep your body solid.
Mixed grip is awesome though, it actually pulls you in to a more correct position I find, and I always find my spine positioning much better with it.
Your set up doesn't help though.
Should be getting on position on the bar
Pulling shoulders back nice and firm
Lock core in and pull
You're missing out the middle part - you're not losing tightness; you're just not putting any tightness in your shoulders before you start![]()
I try to actively do it, hopefully today is an off day and next week will show different results if you dont mind checking again?
strong this.
Also head up/down when deadlifting? I always tend to keep head up
This.Ideally you want to keep it neutral with your spine. People are often told to have your head up, as it encourages you to push your chest up and shoulders back at the same time. However if you already know to do this, keeping it neutral (or 'down) is a better solution!
