Peoples opinions on internet v chrome? I use Firefox as a desktop browser but not sure whether to make the full switch. Can't seem to see any obvious difference on the phone versions.
I only use chrome for all devices now, fav's sync etc....
)Can you not uninnstall chrome? Can't seem to find a way to do it
No you can't because it's in the system partition. If you go into Settings and Apps you can disable it though and the icon will disappear (but the apk won't).
Ah that's good enough then. Quite happy that i can remove the icon.
