Hmm, im just really tempted by the powercolor 7870xt but the lack of CS scares me![]()
Unless the XT is on special offer, you may as well go for the 7950 and go with a firm like Gigabyte (I'd avoid MSI 7950's for the time being).
yup special offer.
is there any after market coolers that would fit the 7870xt?
jony27: lack of CS? customer support?
Which gpu was it replacing arc ?
CS would not budge for me on the 570SO replacement for my 480SO
Was miffed re loss of memory but overclocks very well and is very cool so will do
Runs at 960/2300 on mem max temp in games 70 bug mostly in 60s
@arc - still think its a bit "off" - like with me - they seem to "degrade" their offer depending on how long warranty left .... er - if any warranty left - then warranty is left - no difference whether 1 month or 2 years - especially since replacement product doesn't meet the original specs (ie it has less memory). What would happen if you bought the 480 SOC SPECIFICALLY for playing with LN cooling ? valid reason for buying it since it had a dedicated bios etc .... ?
that said - on a positive - to make you feel better
my 480 SOC - ran Valley Xtreme at 1200 something at the stock SOC clocks (ie pretty heavily overclocked)
my 570 SOC replacement - manages 1500 in Valley oveclocked
that said - the odd game like Skyrim feels a bit more juddery than I remember with the 480 - but hey the card works, it was in pristine condition (I think new) etc - so can't completely complain - and in most games I can't notice a difference other than its much cooler
yeah the memory clocks to near 480/580 bandwidth, my memory runs at 2300 or 2370 depending on volts used - which is 185gb upwardsmemory is actually a bottleneck at higher clocks on the GPU - as the 570 SO is at stock memory speed out of the box
anyway enough OT for me - good luck on the new replacement card - and hope its a good clocker![]()
