- 24 Apr 2012
Which 5/3/1 template are you following?
Delvis you are a strange man! It took you half of that set to remember what a squat was, then the reps got better as you fatigued!
Are you perhaps missing something out of your warm ups? In terms of decisiveness and intensity...
D) which help I think, also added in some ankle mob as I can get tight there sometimes.Squatting without a mirror can make a big difference if that's what your normal is. I found this out tonight as I removed the mirror and filmed some sets. Took me 4-5 sets until I could actually feel my depth and squat in my normal way without a mirror.
Happy to share the rack![]()
Good work. Love the guy hyperextending in the background and sweating using just the bar!![]()
Can't seem to do pull ups without aggravating my shoulder/AC joint thing, even chins aggravate it unlesss me palms face me, even then there is a little something.
I have this, my solution? Don't do pullups. It's like doing a wide grip bench really in terms of snap city positioning, bad times for me. Parallel or palms facing chins are fine, just need to concentrate a bit more to make sure you get back activation not too much bi.
