Trident is 42mm without crown isn't it? I had an old C60 which I moved on and it didn't wear like a big watch. I have girls wrists.
Afraid I haven't tried a Mako. My wife has one of the ladies C60 (pink don't you know!) I can measure that with calliper if you want. May be different crown, not sure
If the spec is the same it would be same case size? If you could then that would be excellent
Actually I'm in London over the next 4 weeks so may be able to drop by CHWard at some point - Not certain though.
Edit*
This is the one I was looking at: http://www.christopherward.co.uk/new-arrival/c60-tri-skoo.html
That's a very good point, I'll check one out then ta![]()
Do it! Then report back here and let us know if its worth a punt![]()
They are getting stock in next week or two and if one is ordered sharpish then pre-orders will be fulfilled apparently.
Thanks Skidder, I also asked the guy on the phone to measure one and he measured 46mm. My Tissot is 44mm with crown (39 without) whilst the Mako is slightly larger and thicker. I think it should work out fine. I'll get an order in and let you know what it's like![]()
I've had a look at one at a party (someone I know vaguely was wearing it, so obviously grabbed it off him for a try on). Very nice. That was the black with orange bezel.
I think the Zeno I have on at the moment is like 48mm without the crown or lugs and about 15mm thick lol You could kill someone with it. Superb
I've pre-ordered it with the orange leather strap. Now the 1-2 week wait will be crushing no doubt. I'll sell the Mako if the C60 is as nice as everything and everything says.Should be able to get a good sum for it as it's the modified version.
Bigger the better!I think the Zeno I have on at the moment is like 48mm without the crown or lugs and about 15mm thick lol You could kill someone with it.
You forget what they weigh as well. I didn't have a watch on, Saturday and I thought I'd lost some fingers I'm so used to having some weight there
Haha you're doomed now. I thought at first you were just skirting the obsession, but you're 2 feet in now![]()
