- 13 Dec 2006
I'm just putting the feelers out but how much would I be looking to spend to get a tidy 182 these days?
That looks an awful lot more than 2deg to me, more like 4-5.
Camber y0!
Could you not just get some camber bolts for the front? They add another 1.5 degrees for £30.
Thanks for the info so far guys. I'm happy with what I am hearing to be honest, MPG I'm looking north of 35 average. I do 8-10k miles per year so not really a big deal, but would prefer less trips to the fuel station. Tax is also fine at £250, and the tyre prices seem reasonable.
My budget will probably get me an 04 model with around 60-70k on the clock, so I will look out for one that has already had the cambelt and dephaser job done!
How rare are the models with the Trophy Recaro seats in? They look fantastic and are really making the car appeal to me...
Darryl has covered most of it. The major expenses are belt services and insurance. If you can find one with the belts recently done then you can avoid that. Insurance is unavoidable really, the image of the car just drags prices up.
The other thing worth mentioning is that while its got Renaultsport underpinnings, large parts of the car are still just cheap French shopping trolley. The plastics are naff, the body panels are half plastic and don't colour match, and the electrics are diabolical.
While the Recaro's are excellent, I wouldn't pay to fit them. I might even be tempted to sell them if I got a car with them.
The French reputation does put me off just slightly, so was coming over here to see if all the bad stories were true...
I'd never really considered running insurance quotes as I thought it would be cheaper than the £420 I am currently paying on the ST. Turns out the little Clio is a tad bit more expensive, but nothing noteworthy really.
Only other cars I have considered so far are MX5 and Civic Sport.
Check insurance quotes with Brentacre, Greenlight and Sky. They are normally very competitive with the clio's.
When you unlock the car theres a little delay before the motion sensors inside are deactivated, so if you open the door too quickly the alarm goes off.
