- 18 May 2010
- London
HH3 has 1 gigabit port.
Yea, but only one.
Might not be the HH3 might be the modem.
Never thought of that actually, a quick off/on with the HH3 and connected straight away.
I've a feeling this has been going on for the past few weeks as I'm having to login to some sites more frequently.
Could you ping bbc.co.uk from cmd?
Pinging bbc.co.uk [212.58.253.67] with 32 bytes of data:
Reply from 212.58.253.67: bytes=32 time=10ms TTL=115
Reply from 212.58.253.67: bytes=32 time=9ms TTL=115
Ping statistics for 212.58.253.67:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 9ms, Maximum = 10ms, Average = 9ms
If you mean me, then here are my results
Code:Pinging bbc.co.uk [212.58.253.67] with 32 bytes of data: Reply from 212.58.253.67: bytes=32 time=10ms TTL=115 Reply from 212.58.253.67: bytes=32 time=10ms TTL=115 Reply from 212.58.253.67: bytes=32 time=10ms TTL=115 Reply from 212.58.253.67: bytes=32 time=9ms TTL=115 Ping statistics for 212.58.253.67: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 9ms, Maximum = 10ms, Average = 9ms
Via Homeplugs at the moment.
how is that done ? so i can try
Anyone know why Utorrent wont connect to hardly any peers and also no speed.
Im on infinity 2
Well i've gone from a nice 70 download speed to 10 lol and i can forget about using torrents im getting 2.7kbs max lol
Will ring them up tomorrow, just as i thought it was all going good it takes a turn for the worse!
