No, it hasn't.
Malware with user privileges is much easier to remove than a root kit with system privileges.
I said scripts
MS13-021 to MS13-26 I think. They are still finding them.
Same happened in windows 7 as well.
No, it hasn't.
MS are still trying to fix the elevation of privilege vulnerability in Windows Defender for Windows 8 and Windows RT.
To completely disable UAC you have to change the values in the registry it's another bug in win 8.
You could try this .. type secpol.msc in the search then Double click on Local Policies then double click on Security Options
then find "User Account Control: Run all administrators in Admin approval mode."
Set it to disabled press OK then reboot. This should work in win 8.
I'm sure doing it this way gives you full UAC off but then Metro apps don't work?
The worst thing about vista was the driver situation, it wasn't a bad os. However few people could get it working properly due to no driver support.
Where am I forcing it down your throat?
You don't have to upgrade and I've said plenty of times give it a try and if you still don't like it, install starts back. It's not like they stop you installing 3rd part mods.
It would be a bad move for MS to bring it back. For the simple reason that people would not even try. The move needs to happen as desktop market is scaling back and we will not see consecutive growth for well a long time. That's not to say its dead, as they are still need in many situations. Just that mobile computing replaces a desktop for a lot of people.
like, not try to force some new way of doing things down the throats of all customers whether they like it (which Glaucus, kitch9 and gareth obviously do, fair enough) or not
/sigh
but still don't like the START Screen.
What's annoying is half the moaning could have been avoided by including a decent tutorial in the early betas. That is when half the fud got going, by people who just didnt know how to use it and didnt bother looking, dispite it being a beta.
Then didnt help the tutorial they put in the final release was almost totally useless.
The amount of people who don't realise you can right click in bottom left hand corner and add custome stuff to the list. Or the number of people who don't realise charms bar is specific to the app. A common integrated menu system is fantastic. You don't need to learn lots of different ones, want settings opn charms and click settings, same for every single app.
The amount of people that are online now and always googling, it's a hard thing to find?
I'm sort of neutral on the Start Screen I can definitely say it can be improved with Blue/8.1 ,9,10 etc.....however I use it when I need to like any tool and it does not really bother me,I hope Microsoft keep coming up with new ideas etc and try to improve on them etc rather then doing u turns.
I can understand some people not liking a certain OS or two for example Win8,just like I don't like some of the Linux Distro's but like others ,however I still think Linux is great and it does not mean the ones I don't like are bad or are no good.
Some of the changes in Win8 a few users find hard to adjust too, we all know what they are but like any OS nothing stays the same forever.
I just hope Microsoft move forward rather then backwards and keep new ideas coming.
Putting a Start button in the task bar is going to make a big difference I think, and they should bundle in a short tutorial while they're at it.
I don't think so it shows that MS still don't have a clue, the lack of start button isn't a problem it's having to switch back and forth between two completely incoherent interfaces that is.
