I got it today and it is the same card as yours. I don't have the thermal glue to stick the heatsinks on though. I was going to order that but talks of the GTX780 started popping up and it's very hard to sell a 12-13" GPU with the accelero attached.
I will order the permanent glue from artic now anyways (will cost ~$7) and if the 780 doesn't cost a fortune and it's in the $500 range then i will sell my 7970 with the stock cooler for it because when i put those heatsinks on with the permanent glue i don't think they will come off with our type of VRMs. They aren't attached to the PCB as well as the stock 7970 VRMs are.
Question though as i have yet to tinker with my card, is it voltage locked? how high is your max OC? I got some crappy ASIC quality 74% compared to the 87% of my last card so i'm curious if i can ever see 1300Mhz again on air.
nope it not voltage locked
currently im sat at 1150/1700mhz with 1.150v,max temp 55c 24/7 gaming stable
in benches ive been upto 1240mhz on the core,and that was with the stock cooler,i havn't tried in benchmarks with the accelero fitted yet
I used the g1 adhesive,if you don't move your pc around or fiddle inside much its fine,theres slight movement of the heatsinks with the g1 but it sticks ok
and oh I wouldn't worry about asic too much
