My GTX 690 rig is the first one I reach for even now and gets used 24/7
If you can go qsli and stick to 1600p the power is awesome. It is something AMD can not match, two HD 7990s just don't work.
How much power does QSLi pull?
Last time I measured with a very overclocked 3960x @4.9ghz and two GTX 690s oced in 3dmark11 I managed 1032 watts at the wall. If I had been running 3dmark vantage it would probably have been about another 40 or so watts higher.
Definitely would require a new PSU then.. Currently using a Corsair AX860 and have a spare OCZ ZX 1000 that whines.
@1080p or 1200p one GTX 690 is plenty if you use two at those resolutions you get bottlenecks. Two GTX 690s are almost the same power as 3 Titans.
In 3dmark11 I can score nearly 39000 for graphics on my GTX 690s, using 3 Titans on a faster CPU I can score 44500 for graphics.
So a quick question for all you shiney new gtx 780 owners. what's the difference between defferent manufacturers cards is it just the clock speeds or are there any other enhancements? I'm going to bite the bullet next week but just doing a bit of research.
When are the 770's due?
A great card if Nvidia get the pricing right could be the 760. It could blow the 7950 out the water price/perf.
What are AMD going to reply
