- 29 Feb 2012
Got to say those rws superdome r smooth as silk...and very clean...
With many, many guns
i'D LIKE to show off my guns but i only let hot girls take pictures of me when am with them.
THIS range looks awesome Atherton Indoor range . where is it?
Know nothing about air rifles..havent touched one since i was like 12 when i would play around with an old level air rifle.
Can anyone gimme some recommendations for a decent air rifle? Something solid and reliable. No clue about makes etc. Or even which actions are the best.
Cheers chaps
Air Arms - Are decent and moderately priced made in England or possibly Turkey now (double check that fact).
BSA - Ditto Air Arms - made in Birmingham.
Weihrauch - Ditto Air Arms - made in Germany.
Daystate - Top end - made in Staffordshire.
Steyr - Top end - made in Austria I think.
Any rifle with Ripley or Hogun in the name are very sought after.
Basic rifle is a springer with a break barrel.
Next rung would be a springer with an under lever and fixed barrel.
Next rung is a gas ram.
Next rung is a single shot PCP.
Next rung is a multishot PCP.
Top rung is a multishot PCP with digital power management like the Daystates.
Cost generally go up as you go down that list.
Lots of people prefer PCPs as they have a smooth action and little recoil. A minority prefer springers because they enjoy the old ways.
What are you after?
As Simon says the Air Arms s410 is a good entry but I prefer my BSA Scorpion SE. Both guns are in the £500-600 price range, I have heard the BSA multishot Ultra is a fine gun too although I was not a fan of the cocking mechanism.
Both the S410 and Scorpion hold enough air for about 90 shots but the last 10 visibly have less power. They are not regulated as standard but that can be done later for about £150 if it bothers you. The scorpion has a relatively flat power curve without one though so it would be a waste - no idea about the S410. More expensive rifles like Simons have a big buddy bottles in the front that can be replaced in the field if needs be, these larger tanks can hold in excess of 300 shots!
To refill the cylinders or buddy bottles will require a pump or divers tank full of air - these will cost about £150. If you have a club it is likely they can refill it for you, but if you are shooting in your own field then you will need to get your own.
