Type R and VTEC owners
:p
I bought it as a mile muncher for which it's very good at. Yes it has higher running costs and purchase price than the 2L Zetec but I wanted something more rewarding dor drive and look at than a 2L Zetec. It was a great car overall, it didn't really go wrong apart from one or two niggles, but it is a ticking time bomb with the DMF and Injectors. But god, the engine, off the motorway it's just crap, the noise, the power delivery - all of it; hateful thing.
I sold it as I could:
a) Insure something better
b) Afford to run something better
c) I didn't need to do that many miles
So I spunked it all on a 13 year old lemon :cool:
Thanks for that. I bought it on the same reason that I need a mile muncher. Which it's great at, and again I have to agree off the motorway the engine is pants.
I miss the ATR. If I wasn't doing a lot of miles, I would have kept mine and would have done a engine rebuild. The bodywork was great for it's age.
Yeah it's not a bad car, I'd always recommend one over the competition but you have to be on the ball with the engine, if you're handy with a spanner then you're laughing really.
Speaking of Honda rebuilds (very 'in' at the moment) you can get a new Teg engine from Spoon for 3.8k: http://www.spoonsportseurope.net/pr...tegra-dc2/b18c-1-8ltr-blueprinted-engine.html
With 7% off this could cover the shipping, wish I'd have known!
Y U NO MENTION BE4?!?!
Someone would be bonkers to spend 3.8k,but think of the JDM points.
Great cars are Hondas. IT's difficult to find a good one unless it's properly been maintained by a true enthusiast. Unfortunately they're now falling into the VTEC innit bruv crew.
The one EP3 I used to see on my daily drive has now been shunted from the front and his mugen grille is broken. Damn my ATR was a great car.
Why did I even enter into this thread. :(
Custom centre caps arrived...hopefully getting the wheels fitted next Saturday, but they might have to wait!
Did a longish drive this weekend, can confirm the Mugen suspension and proper front end geo transforms the handling and steering feel on the FN2, generally its pretty darned chuckable now, and I think it will improve further with the lighter wheels, which will also effectively increase the cars track by 26mm due to the different offset too. Happy :cool:.
Seen 4 FN2's now and they looked rough for the price :(
Where are all the good ones?
Please post if you see any decent ones, with little amount of stone chips, low-ish miles and cared for! Cheers.
Nice! I need caps. Where did you source those?
The caps themselves are universal 60mm ones, 5.95 including postage for a set of 4 from eBay - they are pretty much identical to the buddy club ones.
The gel badges were done by DMB graphics, they will make up badges to alnost any design. I have bought loads of stuff from them over time, great quality.
Well last weekend i sorted my rear brakes out.
Total time 17 hours with two bleeding rounds painting and stuff.
That was never taken out since factory to get handbrake pin going i bad to bang the ****er for 2 hours with hammer and loads of wd40.
Sorted with Motul 5.1 better than it ever was :D
My rear driver side caliper is sticking and I was tempted to try whipping them off myself (do both sides) but after seeing the above photos I think I'll pay someone else to do it. ;)
It's surprisingly easy to do once you've been shown how and you have the correct tools :D
You should definately do it yourself, whilst you're at it you might aswell cover everything in sight with paint.
Just slap it on m8.
Muffin`Ye full rebuild with honda kits like i did fronts last summer :)
I ho have axle stands but they are to high !!!! If i jack car high enough to put it under WHOLE SIDE of the car is in the air.
When i was spraying my wheels my ITR almost fell on ground from 4 axle stands cause of that.
So i use bricks now :p
Not rocket science is it ?? And costs 30f/caliper :P
btw is it ok to hotlink stuff in this topic ??
