Post your mobile phone desktop!
It's changed a bit now. It was simple, I use the following:
Nova launcher prime
Eye in the sky weather (for forecast)
UCCW (Time, Temp and 2 bottom buttons which are uccw-playbars from playstore)
Zooper widgets pro (for battery circle, easy to make)
White icons are Holium five.
Simple RSS widget for news stream.
I originally used Zooper to make the white boxes but ended up just adding them to the background in photoshop to have less widgets running.
I use Pie controls on Paranoid Android rom so no navigation bar or status bar
Something a bit different, don't know about the wallpaper though...... so hard to find a nice minimalistic/patterned/textured wallpaper that I really like, always just end up back on the same one within a day :p :o
Apex launcher
holo icons
google now widget
I use 5 screens with the middle as the main:
Swiping left and right on dock:
App drawer:
Nova launcher prime
How did you amend the colours of the labels?
Yep..
Dashclock with:
Now Playing - Google Play Music
Calendar Appointment (part of Dashclock)
Missed Calls (part of Dashclock)
Apex Notifier - Gmail
Apex Notifier - SMS
Apex Notifier - Battery
BBC Weather
Wireless Information
Network Information
Data Usage
Next Alarm (part of Dashclock)
I'm running Apex Pro, so don't need icons or folders on my screen as I have the App Drawer organised and 'Swipe Gestures' for my mostly used apps (Swipe Up - Phone, Swipe Down - Text etc..) :)
Thanks, having one problem. The widget on my lock screen stays on small when added but if I swipe to the other lock screen and go back the widget changes to full size. If I expand it to full size and lock then unlock - the widget goes back to small.
