The apple tart was my favourite of his. The balance between pastry, apple and spice was rather nice.
Where can I get Apple tart from? I wouldn't mind trying it myself.
You need a quality charger for 18350's and 18650's. As you have found, a cheap charger doesn't cut the mustard.
I went for the Efest double charger. For the £20, it's a good safe charger with two charging modes and it cuts off when fully charged at 4.2v, so it has built in protection, something yours didn't.
Pay around that and you'll get a good charger.
I didn't think the charger itself was actually that bad - it did stop charging when full, it was just the nasty adapter that was sent that has caused the issue.
I'll take a look around at some decent chargers, and get hold of some proper batteries.
I'm also going to need the home address of whoever told me vaping would save me money... This upgraditis is doing anything but...
Just thought I'd say. These people buying ecigs that use 18650 batteries. Be sure you all know how to look after them.
Last thing you want is one of those babies blowing up in ya face.
I have unprotected ones for my fenix flashlight...but I know what I'm doing.
Not saying you don't...just be careful...
Buy a multimeter and make sure it doesn't charge above 4.2 or drop below 3.5ish.
Just some friendly advice.
Hmm, problem...
It seems the UK adaptor for the battery charger, supplied by VaporBreak.com with their Vamo V2 Kit is one to watch; CAREFULLY...
Have sent the above photos to their site contact address to let them know.
Obviously, this has happened just now, so VapourBreak.com haven't had a chance to get back to me - I'll update this post when I hear from them.
I just wanted to let this forum know, as I'm aware a few of us have taken advantage of the site's excellent Vamo price.
Now, anyone got a 650 charger, near Portsmouth, that I could borrow, preferably without the fire risk?![]()
I can send you some I've only used once or twice if you like![]()
When you get the cartos, they are protected on either side by disposable silicone caps, normally known as condoms. No need for a trip down the family planning clinic
There are some really good videos on how to prime cartos and how to use them in tanks. Have a look on youtube. There was one really good Pbusardo video but I can't seem to find it at the moment. I'll have another look tomorrow.
Thanks for the advice. It's good of you to help.
Most of the devices unprotected 18650s are used in are those with protection circuits built in. The mechanical mods don't have this so protected batteries are recommended.
I've not received my 18650s yet but my 18350 batteries charge to 4.2V but stop to function at around 3.2/3.3V. Should I be charging them well before this time and what can happen if I let them discharge to below 3.5V in protected/non-protected devices?
I saw that post earlier today too
It's identical to my situation apart from the fact that I'm planning to start with 18mg strength in my mixes so theoretically it should last a bit under 4 years making the grand assumptions that all my juices are vapeable, I vape the same amount of the same strength every day and I don't use pre-made liquidsOh and also unless I have any major nic disasters!
Having started at 24mg which I don't regret as it took me off the fags, I'm using mainly 18mg juice at the moment and the plan is to gradually cut down over time. Only problem with buying so much nic is that it commits me to vaping for a long period, though If I do decide to stop, I'm sure it won't be difficult to get rid of the nic.
