So... using EVGA Precision X I've managed to get up to;
+180 Gpu clock offset
+170 Mem clock offset
+38Mv Voltage
Does that seem about right or still a bit low because any higher on either setting and it crashes half way through valley bench mark! Also GPU goes up to 87 oC when benching, is that ok?
Thanks.
Core is pretty much what I get but the memory is a bit lower. I take it you have increased the power and temperature targets?
I am running (MSI afterburner):
Power Target: 106%
Temp Target: 90
Voltage: +37Mv (1.2v when gaming)
Core Offset: +180
Memory Offset: +250 (or +500 as I can't remember if the number in Afterburner is quad pumped or not).
Overall clock when gaming is 1189/7000 dropping to 1176/7000 when it passes 80 degrees. It will quite happily play hours of Crysis 3 & BF3 with these clocks.
IIRC my core will bench at +200 (1215 boost) but Crysis 3 crashes out after a few minutes. Perhaps with better cooling (water) it might be ok. Not too fussed TBH.
I would say 87 degrees is fine when benching.
thanks for the help.
did it cost you a lot and do you mind posting some pics for the forum?
