4.1.2 should be available as an ota update on an ee handset.
It's dependant on the carrier. For some reason the networks have the software rolled out at different times.
You could grab a generic 4.1.2 from samfirmwares (I think it's called) and flash it using odin.
I am betting it was her own fault, probably bought some huge cheap battery (especially since that back casing doesn't look like the official/standard one.....)
Either way, nasty injury!![]()
Ive got a crack on the trim above the charging port. Whats the best thing to do, just put a smidge of superglue in there to stop it spreading further ??
