Im not a big fan of the E46 but there is something i really like about that car.
Not tempted to make the wheels turn silver?
Nope, preferre them black.
Applied some Autoglym super resin, then it rained, still some pictures:-
Surprised how clean and unmarked it is really for a track car. Shame the sun went in and the paint has a lovely light blue metallic flake in it which really pops in the sun. I think its Topaz blue.
Also driven it very aggressivlely now in the dry with the DSC off and what a machine, immensely progressive and absolutely tons of grip from the rear-end, surprising considering so much weight is out the rear and its not corner weighted. Also driven it in the wet, my god are these things easy to drift it just does it so progressively with so much ease, not had any silly angles as its on the road, but seems very well setup.
Looking forward to getting the CSL SMG firmware on it soon, for the fast more aggressive shifts.
Found in the service history that in March 2013 it had its allignment done, settings are:-
Front camber = -1.75
front toe = neutral
Rear camber = -1.50
Rear toe = 28 minutes toe in across the axle.
See how goes on track, if I need more camber turnersport top mounts go upto -4 and can get new rear lower arms to get more negative rear camber upto around -3
Really really happy with it and the uprated exhaust seems very very small, guessing its a lightweight one of some sorts. Jobs to do after track day which won't cost too much:-
1. Door cards and pulls for front doors, remove all sound proofing.
2. Get the tar removed from floor, a few hours, but no doubt another 20kg there as that stuff is surprisingly heavy.
3. Get all front carpets/tar removed and metal kick plates fitted.
4. Compression test just to be on safe side, depending on result change out head gasket as a preventive measure, if full compression then no need.
5. Change plugs whilst above being done.
6. Oil/Filter change.
7. Coilovers and corner weighting.
8. Powerflex bushes for subframe.
9. MK60 module fitted so I can have track mode DSC, though DSC off seems safe enough, but they cost little and I can programme it myself.
Hopefully weight will be around 1300kg at this point and 340-350BHP. Can then looks at a CSL boot and CSL front bumper to say another 25kg or so along with 100 cel cats, CSL airbox if can get along with a remap towards 360-370BHP and sub on or below 1300kg.
