- 18 Oct 2002
- South, Scotland
I've been able to OK, Ctrl + C/Ctrl +V usually work fine. Sometimes it gives an error but just try it again.
I don't get anything when I try to do this
Not to mention 99% of AR's have stupidly small clip sizes! Very rare to find a non bandit type with a clip bigger than 30 I find
I had an old S&S gun in BL1 with Roland that started with something like 160 rounds + skills made it about 230 - insane!![]()
Yup copy/paste is the only way! Sometimes you'll have to alt tab back into the game then click once with the mouse button into the first box, but very rare.
Anyone else find it annoying that you cant copy and paste the key in, I know its small but its annoying to me.
there is another way !!! just search Google for Goden Key and see what you find![]()
They often get posted up here, but here's a list for you
http://orcz.com/Borderlands_2:_Golden_Key#Latest_Shift_Codes
Is that the best gun in the game or something?
Also what does farming the treasure room mean, just doing the boss over and over? I did that one last night, the big walrus thing with the snake tongue?
It's one of the best apparently, haven't used it against anything yet. It's very good with The Bee shield because the amp damage isn't really affected by the nerf because the gun fires more bullets than it states on the card. For example the regular Unkempt Harold fires 7 bullets per shot all of which get the full amp damage from the Bee shield because it only states the "8478" instead of "8478x7" for example. The double penetrating prefix is supposed to be the best version of the gun.
As for the treasure room, yeah it's that one. It's not simply killing the Leviathan over and over though as he doesn't respawn so you have to use an exploit where they haven't actually cleaned up its hit box. Just search YouTube for "Farming the treasure room" and you should find it easily enough.
Ugh!
Fed up of always getting my ass handed to me in Hero's Pass I decided to run Zero through Captain Scarlett & Tiny Tina DLC before heading in. Despite being listed as level 30 (to my 34!) and coming up as normal I'm still struggling!
While I'm at it - anyone any idea why sometimes your FFYL timer depletes in seconds? I've no artifacts or weapons effecting that stat which makes it even more confusing!![]()
the timer depletes instantly about every 4 times you die, so it's mega annoying.
but increasing your 2nd wind timer by 122% is no good, because using this means that you have to reduce your gun power, which is already too weak !!!
Mal X said:i wish BL2 didn't have this constant need to switch elemental weapons all the time
Ugh!
You need to do some bar fights to get enough tokens for a DP Harold to kill B Rex in the arena.
