Not having much luck 4.3ghz stable on 1.26v however 4.2ghz stable on 1.17v whats the point of keeping at 4.3 with that much voltage. 4.4 is stable at 1.3v just keeping it at 4.2 for now since temps are amazing at 1.17v max 63 degrees on nh-d14 guess I didn't get a lucky chip![]()
Don't be alarmed just tried friends maximus vi hero board near enough exactly the same however did manage 4.5 on 1.31, however managed 30 mins of prime before hit 90 degrees since I'm running an noctua nh d14 looks like it's all in the chipMine is exactly the same!.
the overvoltage will be llc,try one level lower?
regarding temps it will be mostly due to the ihs paste
Which is the lowest level? I think I tried Standard, which looked to be at the bottom on the graph (in the BIOS).
Pity about the IHS paste, how are some people able to run 4.5GHz+ using 1.3v or more?
just down to pot luck with the chip they get,isnt there low llc? is standard the lowest?
If this is in regard to me yes at 1.3v I touch 85 and barely touch 70 at 1.17vis it hotter at 1.172v? than 1.3v? that doesn't look right
yes that's right less voltage = less heat,not the other way around,sorry if im bit confused
the cooler you can cool the chip also should result in needing slightly less voltage
