Tabletop Warhammer?
I have been very tempted to order the white scars limited edition codex... funny how its the only one still available lol, Id have preferred the successor chapters one personally
Just need one more CSM squad and I have a valid 1k army.
Currently I have:
1 x Chaos Lord (DV model)
1 x Hellbrute
10 x Chaos Space Marines
3 x Chaos Bikers
5 x raptors
5 x Havocs
At some point I will get another box of Bikers so I can swap around and also look at converting a chaos lord on bike.
But for now, I really need to get painting :P
Almost finished the new Librarian model last night. Girlfriend is not a fan of the cherub on it but I think it looks pretty good.
Also came to the conclusion that I might aswell go all the way with the sternguard and get the forgeworld shoulder pads for them aswell. Because ya know they arent quite over the top enough yet. Will also get some terminator ones and maybe some brass etch to add something to my vehicles.
Can someone explain the use of power weapons that have x2 strength I am trying to get my head round the rules since its been a while since I first played 6th edition. Putting a idiots guide/refrence sheet for my friends and brother
IIRC power weapons with x2 strength hit with twice the strength of the user when attacking certain things (IE hitting a tank with one on a character with str4 would be a str8 hit).
I'm probably completely wrong as I've only played a few games since the new edition, and none with an x2 weapon.
DreadKnight and paints arrived! Element Games are really quite cheap and efficient!
What do you guys use to remove mould lines? Will some fine sand paper do the trick?
x2 strength is exactly that, in close combat your strength is x2 whatever it usually is. Please note if you have something that adds to your strength as well then you do that last
So a marine with a power fist and furious charge is Strength nine on the charge (4x2)+1 not strength ten.
Mould lines I scrape a hobby knife (x-acto for me) over it with the blade facing away from whichever direction im scraping
Just been painting my first set of SM in a looong time. I've been following a guide on youtube for Ultramarines here. I've applied a base coat of Vallejo surface primer grey, then a coat of macragge blue and a wash coat of drakenhof nightshade. But the miniatures look a bit rubbish, any idea how I could tidy them up a bit? might just bin them :(
Are you thinning your paints at all? It seems in some areas to be a little heavy, but in others it looks like you can see some of the primer showing through. Other than that, I wouldn't say there's too much to worry about. It's important not to judge a miniature so early on in the process, as they don't often look good until you've got more of the stages done.
I think I've narrowed it down to Novamarines, Sons of Orar, Mentors or Ultramarines (which would mean I could tie in my Captain and Tyrannic War Veterans). Not gonna rush a decision though as I've still got a pile of half-built Guardians in front of me. :p
I'd say so. As long as you avoid getting it into the recesses, it should improve the look of the miniature whilst keeping the shading intact.
