- 25 Nov 2002
- Somerset
Ok been hard at work all weekend.
Not least because I brought loads of new hardware.
But did a rebuild in the 540 with some different water cooling.
Purchased some Promochill rigid Acrylic tube and fittings.
It is the same inner size as my old tube at 10mm but takes up much less space.
Looks really good. Its a shame I cant get water blocks for the new 780 Lightnings so its a bit overkill watercooling a single CPU via a 240 and a 360 rad. Hopefully blocks will become available so I can add them to the loop. Cards only just fit with my 360 rad.
The tube does make the back much neater and I found a good way of running the pipe behind the DVD cage
The stuff is really hard to work with and means draining even to reseat the CPU, but as I don't plan on altering this rig for quite a while that suits me fine.
