I can soon look forward to looking at the mantle piece whilst i poke the fire.
What? Someone had to go there.
Some sites are claiming their will be 6GB 290X variants, anybody know how this is possible with 512bit bus?
Look what i found.
Look what i found.
Mantle does sound awesome, but then Nvidia and AMD are going to try and 'sell' their proprietary software to the consumer.
Sounds great in theory but in reality may not be as great as it sounds.
I personally think in terms of getting more out of hardware, SteamOS will shine, remove the Windows hit altogether and run streamlined OS for gaming. Code direct to the metal. Either way, PC gaming is only going to get bigger from this point onwards.
I think that graph looks very dodgy if all those were done on the same PC.
The overall score for the "blank" of 8623 is far too low for a graphics score of 10232. For it to be correct the overall scores for the Titan and the "blank" would need to be within about 150 points of each other.
Just wondering what you class as ridiculous? I used to spend no more than £300 on a GPU but now I consider more than 500 in that bracket. Guess it is subjective. NOt willy waving either, genuine query.
Anything over £500 id say is too much, and over the 800-900 mark ridiculous. I think the current AMD pricing and the nvidia prices (600 series) is spot on, the 700 series feels way to overprced to me. We will have to wait and see what the UK launch prices are going to be for AMD before i can comment on them.
The most i have spent on a card in the last few years is £260, but id pay around £400 for a card if i felt the need. atm im gaming on a 1080p 60hz screen so theres no need to spend that amount, but when i get a 120hz screen id be looking at buying a high end card.
Have you got any scores on the R9 290X for when the NDA is lifted.
Yep!!!
Hopefully single upto quad!!!
Would need complete PCB revision but is possible by board partners. Not probable though!!
Quad 290X scores? Nice
I feel a new 8pack system coming on![]()
I thought there would be a 4gb/8gb version?
