I've got one... but not really used it. I haven't even got around to dowloading my map or anything
One of the guys on here maps his own though so I'm sure he'll tell you all about it.
I'm not surprised by the sounds of things!
I knew Bradford was a bit if a dodgy place but I didn't know how dodgythanks for the replies guys, you might of saved me from buying a dud!
Tested with fault reader tonight found boost solenoid fault but I think that was logged when my ECU kicked in fail safe mode and started limiting me to 8psi, should I turn boost down on the controller or is it that the solenoid can't handle the extra boost the controller allows and thus I may need a new one?
So pretty much what I suggested you did... right?![]()
Get some pics of the engine bay, location of the MBC, and all the associated pipework. Gives us something to look at and advise for.
Yes and they are fantastic if you are willing to read a bit and put time into testing/logging to see what happens with each and every change.Has anyone had experience with a tactrix cable then?
