Hey guys,
sorry but I'm ripping my hair out at the minute over this card. Any idea's would b appreciated.
I have upgraded my mobo, RAM, cpu, psu and HDD; i5 3670K, 8GB Patriot 1600HMz, Samsung 840 EVO 256GB, Corsair CX750 PSU and Gigabyte H87-HD3. Setting this up on a fresh copy of Windows 7 I find that I cannot get any game to play for mor than a few seconds before it artefacts and crashes. I can CTRL+ALT+DEL and kill the application and sometimes it will state that the display driver stopped responding but has recovered.
I have tried:
...though the same problem still occurs.
- Changing the clock speed to default values;
- Using the backup BIOS on switch number 2;
- Flashing the BIOS on switch 1 from the old Matt.rom (1000/1400) to use the latest Matt.rom (stock @ .90 idle) from the first page of the thread;
- Installed the latest 13.10 beta 2 version of the AMD driver;
- Installed 13.9 after using the AMD driver removal tool from the website;
This is a shame because I was running this card fine before at 1250 core, 1600 memory and 1.175V, without touching the powerlimit+%.
Thanks, Dan.
Matt, when I finally pop in my 2nd 7950 (its still in its box as I'm awaiting something else) when flashing is it advisable to take out my Gigabyte WF3?
I know what I'm, flashed a few GPU's in my time. The 16x PCI-E slot will be the first slot yes?
Anyone else having some slight issues with BF4?
I've got it running LtMatt BIOS (lower stock volts) and I'm running both cards @ 1100/1400 + 25% but BF4 has recently started artifacting. Far Cry 3, Crysis 2 and Crysis 3 have all played fine without issues. Is this a case of BF4 pushing my cards to new limits and exposing an instability or just the fact BF4 is in beta?
What type of artifacts and what gpu temp are you seeing when these artifacts occur?
Black squares popping up, not multicoloured artifacts. Also screen was flickering, I'll try to grab a video. The temps for both cards are mid 60s.
I'm hoping it's just a case of BF4 being buggy, I played for a few hours yesterday without issues.
Here's a quick video.
I've not seen it happen in other games. Having said that I've not seen my 4770K pushed so hard in other games so guessed BF4 was just highlighting OC instability in my 7950s. I'll ignore it for now and hope it's fixed in the final version.Hmm yes ive not seen that in mine. Does it happen in other games? If not id put it down to a beta bug.
...Have you updated your motherboard BIOS to the latest version, or tried the card in a second system?
Dan if you're overclocking the power limit should be at +20% if you're using a flashed bios or 30%= if you're using the stock bios.
Also guys i found that all the bios in the OP broke sleep for me. Sometimes the computer does not wake from sleep. However the 0.950mv bios appears to fix this issue. So if you have that problem, you know which one to use.
Hi folks, just bought one of these. Performance is great but I see lots of utilization dips from 100% to 10-20% for no apparent reason. Happens at stock and oc clocks. Fps remain stable during these. Is it an issue with how afterburner reports this? Is it fixable without a new bios?
Just installed the 2nd card and flashed it to the bios in post #2.
BF4 Beta was fine with the odd lag.
Fired up Skyrim and getting really bad screen tear, fps goes up to 120![]()
