I think maybe we need to say 'bru' and 'dem feels' a lot to be in with a shot of finding out!![]()
Simple story:
Joe has a GF called Lois.
Joe is punching well above his weight.
Joe is on a promise to share naughty videos.
Joe WILL comply.
Simple story:
Sloots gonna sloot, in for creampie of Joe's dads tash.
Hospital tomorrow to find out the damage i have done to my hand.
'bru'; 'dem feels'![]()
Still waiting for crepes
Hospital tomorrow to find out the damage i have done Joe's dad's tash.
Omg the formatting, my eyes, my eyeeeeeeeees. But srsly it's not that bad.
In other news, the return of dem HST 15s feels. Help..... me.....![]()
Thanking you.Hey lads, is there anywhere you recommend to buy belts from? I'm looking for a belt for DLing. If you have any suggestions please drop me a msg in trust.Thanking you.
Do you really need one? If you need it for deadlifting, are you sure you are keeping your lumbar under control? Bear in mind your 1RM work is not necessarily the best indicator of a requirement for one...
If you are dead-set on getting one, then practically a two-prong one is probably a best bet (depending on how tall you are). I would always suggest trying one on and seeing how you get on with it... so this may restrict where you can get them from (the local leisure club has Maximuscle-branded ones for crying out loud...?), but I would also talk to your coach/other people in the gym to find out where to get this sort of stuff from, because it will be quite important having somebody who actually knows about weightlifting that can help you find the belt that works for you.
It was my PT that suggested I get one with the fact that I lifted the 95/97kg untrained & I'm happy to see if I can get to 130kg. I called in the local shop but they were out of stock so thought I'd throw the question out here just on the off chance.
Edit: Height = 5ft
thanks for the advice
