Caporegime
- 7 Apr 2008
- Lorville - Hurston
Cool thanks
Rumours suggest the 15th.
NDA lifts today?
I really hope the 290 isn't priced too high, and that is uses 2 6-pin power connections. I don't like how power hungry even AMD's "new" midrange is.
Fairly sure it's an 8 pin / 6 pin configuration?
If it is, I'll just pick up a 7950. AMD need to get their power usage sorted, the 280/'s(new mid range, using as much as flagship) also use 6+8pin, and I would have hoped for a refresh to bring down power usage. Instead we get a rebadge.![]()
That's a thought, my 7970 platinums come with two 8 pin connectors.![]()
I can understand people that like to overclock a lot, they want it to be able to use more power. Yet how many normal folks buy cards that like to draw more than their entire system combined?
Who cares? I am glad to hear the salvage part (290 non-X) also has an 8pin.
It seems the R9 series has 64 ROPS:
http://videocardz.com/46571/amd-radeon-r9-290x-confirmed-feature-64-rops
64 rops on the 290X and the 290 Pro.
8 pin connectors aren't exactly new. Besides if you want the best performance available it's only normal for the fastest cards to draw the most power surely!
Nice article, all looks pretty genuine. If those prices are accurate I will be cashing in my pre-order deposit for a 290. 256 stream processors extra ain't worth $150.It seems the R9 series has 64 ROPS:
