- 16 Aug 2009
Also is it safe to combine the 2k HD textures when your already using the official HD pack?
Don't bother with the official HD pack, gobbles lots of HDD space and I couldn't tell the difference from the original, honestly. If acquired via Steam you can't uninstall it, only disable it in teh load order. You'll have to contact Steam Support to have it permanently removed from your account.
Get the 2k HD textures pack instead, and the Lite version at that, I can't tell it apart from the other and it uses less Vram.
Other than that, I would recommend the amidian book of armours, weapons and misc for much more detailed textures than vanilla, the XCE facial pack; keeps vanilla faces but removes compression artifacts, Improved NPC clothing; looks the same but higher resolution, Quality Road Maps for sharper maps and roads and the unofficial patches for Skyrim/Dawnguard/Dragonborn/Hearthfire packs (some mods may not like skyrim patch so read first). Oh and I'd probably throw in SkyUI if like me you find the official inventory system extremely lacking (requires SKSE).
Those are the only essential for me, anything after that is personal preferences, for instance some people swear by the ENB lighting mods but I don't get on with them at all.
