Are we expecting this to hit Windows Update any time soon? Or do we have to manually upgrade to it?
Its in the store not windows update, open up the app store and you should be greeted with a big windows 8.1 screen saying upgrade.
Off course you can delete it, same as any other version of windows(been the same since at least xp if not before), its protected.
All you need to do is charm bar >search >type "disk" > select: clear disk space by deleting unesacery files > clean up system files > select: previous windows installations then click ok.
mine also. it's been about a hour, it's at 39%.This is downloading so slowly and I have no idea at what speeds. Going to take a while.
There is no 'previous windows installations' options in clear up disk space for me.
Can't manually delete the folder as its protected.
Thats because you missed a step out. Re-read the instructions.you need to click the clean up system files button, bottom left. It'll then close and relaunch the disk cleaner app, which will then have the option in the list.
Just followed it twice and "old windows files" aren't there for me.
Woohoo! Downloading is really flying now from the VLSC. Windows 8.1 here I come.Can you actually get them to download though? They keep getting so far through than I get a fatal error, even when using the download manager.
Anyone with an AMD switchable graphics laptop? I'm having an annoying time trying to get it to work again after updating to 8.1. I want to game on my 7670M, not the HD 4000...
Q: I keep getting an error when using DX11 on Win 8.1 RTM?
A: The dxgi.dll needs to be updated to support some DXGI changes that Win8.1 introduced. Future versions of the injector should have Win8.1 support. You can still use DX9 games with SweetFX under Win8.1, and some DX10/11 still work on Win8.1. RadeonPro also works.
Can't seem to update my Surface RT's 8.1 preview.
Wonderful.
How do i set it to got straight to desktop from boot up![]()
