woooah - what did 8.1 do to my free space !
before update 11.8gb free (256 Samsung 840 Pro) - after 27.8 !!
Windows 8.1 Pro - SecureBoot isn't configured correctly Build 9600
They're on my VLC
You have installed the GA Rollup 1 updates yes?
1. Press the Windows and X keys together on your keyboard while running Windows 8.1 Preview.
2. Click on the Windows PowerShell (Admin) option in the menu that has popped up.
3. There may be a User Account Control prompt, if it asks for a password, type in your user account password. And if it asks for a confirmation, click Yes.
4. Now, a PowerShell window will open up with a prompt at PS C:\Windows\System32, type in the following commands at that prompt one by one and hit Enter after typing in each command. I have provided one command in one line:
cd\
Confirm-SecureBootUEFI
Now, depending on your BIOS/UEFI settings, you may get three outputs - True, False or Cmdlet not supported on this platform. .
I figured out how to solve the problem today:
I navigated to Edit Group Policy (via search) -> Administrative Templates -> All Settings ->
double clicked "use enhanced boot configuration data validation profile", which was not configured and hit "enable".
After a restart, the watermark was gone.
Not here, maybe its staggered, I have all of the 8 ones but no 8.1 :/
Weirdly I can go into the keys section and find keys for it but no ISO's lol
Yep, mine is hanging again. Might be my Steel series keyboard as well. I'm going to try and force it back to 8 and leave it for a few days.
At least windows is working just a water mark, try telling that too us in the ios7 thread, even after two updates.
Not good, but large releases will have issues as theres so many hardware configurations. Its how fast they solve it. Ios cant even say that with only a dozen or so hardware configurations.
Several things you can try.
Is secure boot enabled in bios?
If its false you probably need to re-enter the secure code from the manufacturer.
Some more info on ms, like this thread.
http://answers.microsoft.com/en-us/...AllReplies,AllReplies&page=1&tm=1380036593566
Pc is only about half way, does anyone know what will happen with the download if I shut the pc down?
If you just shut down whilst it is downloading it will start from where it left off when you turn it back on.
This is what I am doing.
